MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement, Clutch Assembly: step 1, image 1 of 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement, Clutch Assembly: step 1, image 2 of 2
    • Remove the two pieces of kapton tape covering the display data cable.
    • Remove the strip of tape securing the iSight cable to the LCD.
    • Peel the three antenna straps off the lower edge of the LCD.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 2, image 1 of 1
    • Disconnect the display data cable by pulling its connector toward the bottom edge of the display, away from the socket on the LCD.
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 3, image 1 of 1
    • Remove the two Phillips screws securing the ground straps for the display data cable and LED driver board cable to the clutch cover.
  4. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 4, image 1 of 1
    • Remove the Phillips screw hidden behind the display data cable.
  5. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 5, image 1 of 1
    • Remove the three Phillips screws behind antenna straps along the bottom edge of the display.
  6. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 6, image 1 of 1
    • To remove the clutch assembly, first insert the flat end of a spudger into the gap between the clutch hinge and the clutch cover where the cables exit.
    • While prying the clutch assembly away from the clutch hinge with your spudger, use a plastic opening tool to increase the gap between the clutch cover and the front display bezel.
    • Work your way along the length of the clutch cover to fully separate the adhesive.
  7. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 7, image 1 of 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Clutch Assembly Replacement: step 7, image 2 of 2
    • Push the clutch assembly off each of the clutch hinges and remove it from the display.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,104
