Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan
  1. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan, Battery: step 1, image 1 of 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan, RAM Shield: step 2, image 1 of 1
    • Remove the three identical Phillips screws from the memory door.
  3. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 3, image 1 of 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan, Upper Case: step 4, image 1 of 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 5, image 1 of 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 6, image 1 of 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 7, image 1 of 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 8, image 1 of 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 9, image 1 of 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 10, image 1 of 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan, Right Fan: step 11, image 1 of 1
    • Disconnect the right fan cable from the logic board by placing a spudger beneath the cable and lifting up.
  12. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 12, image 1 of 1
    • Remove the three silver T6 Torx screws securing the right fan to the logic board and lower case.
  13. Installing MacBook Pro 15" Core 2 Duo Model A1211 Right Fan: step 13, image 1 of 1
    • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 45,693
