MacBook Pro 13" Unibody Mid 2009 RAM Replacement
  1. MacBook Pro 13" Unibody Mid 2009 RAM Replacement, Remove the lower case screws: step 1, image 1 of 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 RAM Replacement, Lift the lower case away: step 2, image 1 of 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 RAM Replacement, Battery: step 3, image 1 of 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 RAM Replacement, RAM: step 4, image 1 of 1
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  5. MacBook Pro 13" Unibody Mid 2009 RAM Replacement: step 5, image 1 of 1
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 105
All Time: 230,760
