Installing MacBook Pro 13" Unibody Late 2011 Fan
  1. Installing MacBook Pro 13" Unibody Late 2011 Fan, Lower Case: step 1, image 1 of 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. Installing MacBook Pro 13" Unibody Late 2011 Fan: step 2, image 1 of 2 Installing MacBook Pro 13" Unibody Late 2011 Fan: step 2, image 2 of 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. Installing MacBook Pro 13" Unibody Late 2011 Fan, Battery Connection: step 3, image 1 of 2 Installing MacBook Pro 13" Unibody Late 2011 Fan, Battery Connection: step 3, image 2 of 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. Installing MacBook Pro 13" Unibody Late 2011 Fan: step 4, image 1 of 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. Installing MacBook Pro 13" Unibody Late 2011 Fan, Fan: step 5, image 1 of 3 Installing MacBook Pro 13" Unibody Late 2011 Fan, Fan: step 5, image 2 of 3 Installing MacBook Pro 13" Unibody Late 2011 Fan, Fan: step 5, image 3 of 3
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. Installing MacBook Pro 13" Unibody Late 2011 Fan: step 6, image 1 of 1
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. Installing MacBook Pro 13" Unibody Late 2011 Fan: step 7, image 1 of 1
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
Phillip Takahashi
86,785 Reputation
87 Guides authored
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 48
All Time: 39,664
