MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain attached to the hard drive bracket.
  2. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  3. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: step 3, image 1 of 1
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Don't try to completely remove the hard drive just yet. It is still attached to the hard drive cable.
  4. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: step 4, image 1 of 2 MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: step 4, image 2 of 2
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,336
