MacBook Pro 13" Unibody Early 2011 Battery Connection Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 13" Unibody Early 2011 Battery Connection Replacement, Battery Connection: step 1, image 1 of 2 MacBook Pro 13" Unibody Early 2011 Battery Connection Replacement, Battery Connection: step 1, image 2 of 2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  2. MacBook Pro 13" Unibody Early 2011 Battery Connection Replacement: step 2, image 1 of 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 2,380
