Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly, AirPort/Bluetooth Assembly: step 1, image 1 of 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
  2. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 2, image 1 of 1
    • Carefully pull the camera cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
  3. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 3, image 1 of 2 Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 3, image 2 of 2
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  4. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 4, image 1 of 2 Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 4, image 2 of 2
    • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
    • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
  5. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 5, image 1 of 2 Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 5, image 2 of 2
    • Using the method described in the last step, disconnect the remaining three antenna connectors.
    • De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
  6. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 6, image 1 of 1
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  7. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 7, image 1 of 1
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
  8. Installing MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Assembly: step 8, image 1 of 1
    • Remove the AirPort/Bluetooth assembly, minding the fragile antenna contact near the corner of the upper case.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,133
