MacBook Pro 13" Retina Display Mid 2014 SSD Replacement
  1. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 3, image 2 of 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement, Battery Connector: step 4, image 1 of 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 5, image 2 of 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 6, image 1 of 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement, SSD: step 7, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  8. MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 8, image 1 of 3 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 8, image 2 of 3 MacBook Pro 13" Retina Display Mid 2014 SSD Replacement: step 8, image 3 of 3
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its socket on the logic board.
    • Only lift the end of the SSD enough to allow you to pull it out—about 1/4".
Sam Goldheart
465,847 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,182 Guides authored
Past 24 Hours: 34
Past 7 Days: 271
Past 30 Days: 1,497
All Time: 626,052
