Introduction
Use this guide to replace the right speaker.
This guide is for the speaker on the right side of your notebook when operating normally, during most of the guide it will be on the left, as your laptop will be upside down.
Tool used on this step:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
Remove the following screws securing the right speaker to the upper case:
One 5.7 mm T5 Torx screw
One 6.5 mm T5 Torx screw
One 3.8 mm T5 Torx screw
