Introduction
Use this guide to replace a faulty MagSafe DC-In board.
Tool used on this step:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Use the MagSafe DC-In board cable to pull the board out and up from the upper case to remove it.
