MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement
  1. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 3, image 2 of 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Battery Connector: step 4, image 1 of 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 5, image 2 of 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 6, image 1 of 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Heat Sink: step 7, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Heat Sink: step 7, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Heat Sink: step 7, image 3 of 3
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 8, image 2 of 2
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 9, image 1 of 1
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 10, image 2 of 2
  11. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Fan: step 11, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Fan: step 11, image 2 of 2
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 12, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 12, image 2 of 2
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 13, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 13, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 13, image 3 of 3
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 14, image 1 of 1
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 15, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 15, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 15, image 3 of 3
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
  16. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Logic Board Assembly: step 16, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Logic Board Assembly: step 16, image 2 of 2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  17. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 17, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 17, image 2 of 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  18. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 18, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 18, image 2 of 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  19. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 19, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 19, image 2 of 2
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  20. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 20, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 20, image 2 of 2
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  21. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 21, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 21, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 21, image 3 of 3
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  22. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 22, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 22, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 22, image 3 of 3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  23. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 23, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 23, image 2 of 2
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  24. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 24, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 24, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 24, image 3 of 3
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  25. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 25, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 25, image 2 of 2
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  26. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 26, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 26, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 26, image 3 of 3
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  27. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 27, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 27, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 27, image 3 of 3
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  28. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 28, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 28, image 2 of 2
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  29. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 29, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 29, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 29, image 3 of 3
    • If necessary, peel back any tape covering the trackpad cable connector.
  30. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 30, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 30, image 2 of 2
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  31. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 31, image 1 of 1
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
  32. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 32, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 32, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 32, image 3 of 3
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
  33. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement, Logic Board: step 33, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  34. MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 34, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 34, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement: step 34, image 3 of 3
    • Lift the free end of the SSD up slightly and pull it straight out of its socket on the logic board.
Sam Goldheart
466,249 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,442 Guides authored
Past 24 Hours: 14
Past 7 Days: 51
Past 30 Days: 216
All Time: 89,953
