MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 2 of 2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  2. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 2, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  3. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 3, image 2 of 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  4. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 4, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 4, image 2 of 2
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  5. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 5, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 5, image 2 of 2
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 6, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 6, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 6, image 3 of 3
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  7. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 7, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 7, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 7, image 3 of 3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  8. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 8, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 8, image 2 of 2
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  9. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 9, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 9, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 9, image 3 of 3
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  10. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 10, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 10, image 2 of 2
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  11. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 11, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 11, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 11, image 3 of 3
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 12, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 12, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 12, image 3 of 3
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  13. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 13, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 13, image 2 of 2
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  14. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 14, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 14, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 14, image 3 of 3
    • If necessary, peel back any tape covering the trackpad cable connector.
  15. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 15, image 1 of 2 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 15, image 2 of 2
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  16. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 16, image 1 of 1
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
    • When reassembling, install all five screws loosely, position the logic board, and then tighten evenly.
  17. MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 17, image 1 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 17, image 2 of 3 MacBook Pro 13" Retina Display Late 2013 Logic Board Assembly Replacement: step 17, image 3 of 3
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
    • When reinstalling, make sure the keyboard, keyboard backlight, MagSafe, and microphone cables don't get trapped beneath the logic board.
    • Also be sure to slide the ports' metal EMI fingers under the side of the case, not over.
Sam Goldheart
465,927 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,267 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 12
All Time: 250
