MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
23
All Time:
984
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prereq for removing the upper case and battery.
    1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: step 1, image 1 of 3 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: step 1, image 2 of 3 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: step 1, image 3 of 3
      • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
      • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
      Ask FixBot
    2. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: step 2, image 1 of 1
      • Remove the SSD assembly from the upper case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 984
