Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly, SSD Assembly: step 1, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly, SSD Assembly: step 1, image 2 of 2
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
  2. Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 2, image 1 of 3 Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 2, image 2 of 3 Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 2, image 3 of 3
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  3. Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 3, image 1 of 1
    • Remove the SSD assembly from the upper case.
  4. Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 4, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the SSD tray.
  5. Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 5, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 5, image 2 of 2
    • Insert the edge of plastic opening tool between the SSD and the SSD tray, opposite to the socket side of SSD tray.
    • Pry the side of the SSD opposite the SSD tray socket out of the SSD tray.
    • Only lift the SSD up far enough to grab the sides of it with your fingers. Lifting it any more may damage the card or socket.
  6. Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 6, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 SSD Assembly: step 6, image 2 of 2
    • Carefully pull the SSD straight out of its socket on the SSD tray.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 144
