Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct
  1. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 3, image 1 of 3 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 3, image 2 of 3 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 3, image 3 of 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Battery Connector: step 4, image 1 of 1
    • Remove the plastic cover adhered to the battery contact board.
  5. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 5, image 1 of 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 6, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 6, image 2 of 2
    Buy
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 7, image 1 of 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 8, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 8, image 2 of 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Battery Contact Board: step 9, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Battery Contact Board: step 9, image 2 of 2
    Buy
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Heat Sink Assembly: step 10, image 1 of 1
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
  11. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 11, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct: step 11, image 2 of 2
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  12. Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Right Fan Duct: step 12, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 Right Fan Duct, Right Fan Duct: step 12, image 2 of 2
    • Carefully remove the right fan bracket from the edge of the heat sink.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,215
