Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Use this guide to replace the right fan duct.
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. During reassembly, gently push down the center of the lower case to reattach the two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  3. Remove the plastic cover adhered to the battery contact board.
    • Remove the plastic cover adhered to the battery contact board.
  4. Remove the following screws securing the battery connector board to the logic board:
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  5. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  6. Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  7. Carefully lift the battery connector board up off the logic board. It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  8. Grasp the Interposer with tweezers. An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  9. Remove the following screws securing the heat sink to the logic board assembly:
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  10. Carefully remove the right fan duct from the edge of the heat sink. Carefully remove the right fan duct from the edge of the heat sink.
    • Carefully remove the right fan duct from the edge of the heat sink.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 909
