Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable
  1. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 3, image 1 of 3 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 3, image 2 of 3 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 3, image 3 of 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable, Battery Connector: step 4, image 1 of 1
    • Remove the plastic cover adhered to the battery contact board.
  5. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 5, image 1 of 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 6, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 6, image 2 of 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 7, image 1 of 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 8, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 8, image 2 of 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable, Battery Contact Board: step 9, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable, Battery Contact Board: step 9, image 2 of 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable, I/O Board Data Cable: step 10, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable, I/O Board Data Cable: step 10, image 2 of 2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  11. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 11, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 11, image 2 of 2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  12. Installing MacBook Pro 13" Retina Display Late 2012 I/O Board Data Cable: step 12, image 1 of 1
    • Lift and remove the I/O board data cable from the MacBook Pro.
Past 24 Hours: 1
Past 7 Days: 31
Past 30 Days: 46
All Time: 4,159
