Installing MacBook Pro 13" Retina Display Late 2012 Heat Sink Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Pro 13" Retina Display Late 2012 Heat Sink Assembly, Heat Sink Assembly: step 1, image 1 of 1
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
  2. Installing MacBook Pro 13" Retina Display Late 2012 Heat Sink Assembly: step 2, image 1 of 2 Installing MacBook Pro 13" Retina Display Late 2012 Heat Sink Assembly: step 2, image 2 of 2
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
