Introduction
Prereq only.
Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
Connect the long-sleeved cable to the center socket.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
Gently pry the AirPort board upwards, but do not remove it.
