MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: step 1, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: step 1, image 2 of 2
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
  2. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 2, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 2, image 2 of 2
    • Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
    • Be careful not to damage the cable. If it doesn't peel up easily, apply a little heat from an iOpener, heat gun, or hair dryer to soften the adhesive, and try again.
  3. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 3, image 1 of 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 3, image 2 of 3 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 3, image 3 of 3
    • If necessary, peel back any tape covering the trackpad cable connector.
    • Use the end of a spudger to flip the retaining tab on the ZIF connector.
  4. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 4, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 4, image 2 of 2
    • Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
  5. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: step 5, image 1 of 1
    • Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
Sam Goldheart
466,174 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,795
