MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement
  1. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: step 3, image 1 of 2 MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: step 3, image 2 of 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
Andrew Optimus Goldheart
503,115 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,303 Guides authored
Past 24 Hours: 9
Past 7 Days: 47
Past 30 Days: 323
All Time: 50,851
