Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray
  1. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 3, image 1 of 3 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 3, image 2 of 3 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 3, image 3 of 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, Battery Connector: step 4, image 1 of 1
    • Remove the plastic cover adhered to the battery contact board.
  5. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 5, image 1 of 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 6, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 6, image 2 of 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 7, image 1 of 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 8, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 8, image 2 of 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, Battery Contact Board: step 9, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, Battery Contact Board: step 9, image 2 of 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, SSD Assembly: step 10, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, SSD Assembly: step 10, image 2 of 2
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
  11. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 11, image 1 of 3 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 11, image 2 of 3 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 11, image 3 of 3
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  12. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 12, image 1 of 1
    • Remove the SSD assembly from the upper case.
  13. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 13, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the SSD tray.
  14. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 14, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 14, image 2 of 2
    • Insert the edge of plastic opening tool between the SSD and the SSD tray, opposite to the socket side of SSD tray.
    • Pry the side of the SSD opposite the SSD tray socket out of the SSD tray.
    • Only lift the SSD up far enough to grab the sides of it with your fingers. Lifting it any more may damage the card or socket.
  15. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 15, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray: step 15, image 2 of 2
    • Carefully pull the SSD straight out of its socket on the SSD tray.
  16. Installing MacBook Pro 13" Retina Display Early 2013 SSD Tray, SSD Tray: step 16, image 1 of 1
    • SSD tray remains.
Sam Goldheart
465,870 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,218 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 7,165
