Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink
  1. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 2, image 1 of 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 3, image 1 of 3 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 3, image 2 of 3 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 3, image 3 of 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Battery Connector: step 4, image 1 of 1
    • Remove the plastic cover adhered to the battery contact board.
  5. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 5, image 1 of 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 6, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 6, image 2 of 2
    Buy
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 7, image 1 of 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 8, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 8, image 2 of 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Battery Contact Board: step 9, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Battery Contact Board: step 9, image 2 of 2
    Buy
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Heat Sink Assembly: step 10, image 1 of 1
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
  11. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 11, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink: step 11, image 2 of 2
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  12. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Right Fan Duct: step 12, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Right Fan Duct: step 12, image 2 of 2
    • Carefully remove the right fan duct from the edge of the heat sink.
  13. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Left Fan Duct: step 13, image 1 of 2 Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Left Fan Duct: step 13, image 2 of 2
    • Carefully remove the left fan duct from the edge of the heat sink.
  14. Installing MacBook Pro 13" Retina Display Early 2013 Heat Sink, Heat Sink: step 14, image 1 of 1
    • Heat sink remains.
Sam Goldheart
466,487 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 37
All Time: 5,616
