MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement
  1. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Tools: step 1, image 1 of 1
    • Loctite super-glue remover, to remove any superglue residue, be careful its like water.
    • Loctite super-glue, for sticking down the clips.
    • A toothpick to spread the glue. You need something long and thin. Please avoid metal if possible.
  2. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Check if the space is working: step 2, image 1 of 1
    • Clean the middle mechanical bit with a cloth to make sure that it is working when you place the peg in.
    • Ignore the superglue if you see it, that was removed later on.
    • Use a dry kitchen towel and rub over the gold mechanical bits, then place the middle clip.
    • Don't glue it yet, this is just to check that the space function is working.
    • Open up Word and see if the spacebar works.
  3. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Positioning the hinges correctly: step 3, image 1 of 1
    • should look like this.
    • the top part of the hinges should have a slight bigger gap for the silver bars, the bottom gap is at the lower left.
  4. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Placing the hinge: step 4, image 1 of 1
    • simple step, just place in the hinge... properly
  5. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Right Clip: step 5, image 1 of 1
    • only use seriously small amount of glue. place in 2 dots and spread it with a pencil etc. something long and thin.
    • make sure you spread it enough like I did, this can effect the spacebar when pressing,
    • the orange highlighted bit is the amount of glue I used.
  6. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, left clip: step 6, image 1 of 1
    • now do the exact same for the left-clip. only need alit bit of glue, and make sure you spread it left & right.
  7. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Middle Peg, be careful its facing the correct way.: step 7, image 1 of 2 MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Middle Peg, be careful its facing the correct way.: step 7, image 2 of 2
    • make sure that the middle-peg is in the correct direction, at the back is a "U" like symbol, it needs to be facing down.
    • now when placing in the middle-clip, only apply small dots of glue in each corner and do-not spread it.
    • then place on-top, the middle-clip, make sure its facing the right way.
  8. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Placing the Spacebar: step 8, image 1 of 1
    • this part is tricky.
    • first clip in the bottom 4 hooks like I did, and then you're going to close it likes its a book.
  9. MacBook Pro 13" Late 2016 Function Keys Spacebar Replacement, Pushing the spacebar in: step 9, image 1 of 1
    • push in where I have drawn in the yellow arrows, you should heard 4 clicks each time.
    • push each clip 1 by 1.
Amnesi4c
253 Reputation
1 Guide authored
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 222
All Time: 6,506
