How to Change Mortise Lock and its Cylinder
  1. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: step 1, image 1 of 3 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: step 1, image 2 of 3 How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: step 1, image 3 of 3
    • Determine the position of the screws on both door handles and the front plate.
  2. How to Change Mortise Lock and its Cylinder: step 2, image 1 of 2 How to Change Mortise Lock and its Cylinder: step 2, image 2 of 2
    • Use a flathead screwdriver to remove the eight 6 mm screws on both handles.
  3. How to Change Mortise Lock and its Cylinder: step 3, image 1 of 3 How to Change Mortise Lock and its Cylinder: step 3, image 2 of 3 How to Change Mortise Lock and its Cylinder: step 3, image 3 of 3
    • Pull out the door handles on both sides of the door.
  4. How to Change Mortise Lock and its Cylinder: step 4, image 1 of 3 How to Change Mortise Lock and its Cylinder: step 4, image 2 of 3 How to Change Mortise Lock and its Cylinder: step 4, image 3 of 3
    • Pull out the spindle (the rectangular piece of metal) from the door.
  5. How to Change Mortise Lock and its Cylinder: step 5, image 1 of 3 How to Change Mortise Lock and its Cylinder: step 5, image 2 of 3 How to Change Mortise Lock and its Cylinder: step 5, image 3 of 3
    • Loosen the two 6 mm flathead screws at the top and bottom of the lock using a flathead screwdriver.
    • Remove the third 6 mm Phillips screw in the middle using a Phillips #1 screwdriver.
  6. How to Change Mortise Lock and its Cylinder: step 6, image 1 of 2 How to Change Mortise Lock and its Cylinder: step 6, image 2 of 2
    • Pull the lock cylinder out to either side of the door.
  7. How to Change Mortise Lock and its Cylinder: step 7, image 1 of 3 How to Change Mortise Lock and its Cylinder: step 7, image 2 of 3 How to Change Mortise Lock and its Cylinder: step 7, image 3 of 3
    • Grasp the mortise lock on either side and pull it out from the edge of the door.
Hikmat Guliyev
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 62
All Time: 3,621
