Introduction
更换硬盘时,必须将四个定位销(用T6螺丝刀拆下)从旧硬盘换到新的。
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
568 other people completed this guide.
Special thanks to these translators:
100%
笑得像个300斤的孩子 is helping us fix the world! Want to contribute?
Start translating ›
16 Comments
I'd suggest using the free software "Super Duper" to clone the hard drive. It worked wonders for me and after the 2 hour clone, I was up and running in 5 minutes!
I wholeheartedly agree. Super Duper! made the task effortless.
The T6 torx screws on the side of the existing Hitachi drive fit my Crucial M500 240GB replacement perfectly. Be aware that they were originally installed into the HDD with blue Loctite, so it takes a bit of effort to break them loose.
Thanks ifixit for excellent guidance!
What do you do when your laptop doesn't read your new hard drive?
If your hard drive dosent connect. you might need to change your hard drive connect cable . The second option is that you need a strip to replace your hard drive with DVD rom.
