Introduction
Prerequisite only guide to remove the USB ports in a MacBook Neo.
Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the USB ports connector cover.
Use a Torx Plus 5IP driver to remove the four 2.8 mm‑long screws securing the USB ports.
Use a Torx Plus 5IP driver to partially install the four 2.8 mm‑long screws securing them.
Plug both ends of a USB‑C to USB‑C cable into the ports. If either port feels stiff, shift the port and reconnect the cable until it feels smooth.
Fully tighten the screws securing the USB ports, and disconnect the cable from both.
Skip the step above this one.
