Shop the Holiday Gift Guide
MacBook Neo Screen Removal
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
16
All Time:
139
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to remove the screen on a MacBook Neo.
Tools
    1. MacBook Neo Screen Removal, Disconnect the display cable: step 1, image 1 of 2 MacBook Neo Screen Removal, Disconnect the display cable: step 1, image 2 of 2
      • Use the flat end of a spudger to gently push under the metal buckle of the display cable connector, located on the top‑right corner of the logic board, to unclip it.
      Ask FixBot
    2. MacBook Neo Screen Removal: step 2, image 1 of 2 MacBook Neo Screen Removal: step 2, image 2 of 2
      • Grab the buckle and cable together and gently pull the connector straight out of its socket.
      Ask FixBot
    3. MacBook Neo Screen Removal, Disconnect the camera cable: step 3, image 1 of 3 MacBook Neo Screen Removal, Disconnect the camera cable: step 3, image 2 of 3 MacBook Neo Screen Removal, Disconnect the camera cable: step 3, image 3 of 3
      • Repeat this procedure to disconnect the camera cable, located on the left edge of the logic board.
      • To reconnect:
      • Grip the buckle and insert the connector fully into its socket. Realign it as necessary and don't try to force it in.
      • Flip the buckle over the socket and press it down until it clicks into place.
      Ask FixBot
    4. MacBook Neo Screen Removal, Free the camera cable: step 4, image 1 of 3 MacBook Neo Screen Removal, Free the camera cable: step 4, image 2 of 3 MacBook Neo Screen Removal, Free the camera cable: step 4, image 3 of 3
      • Pick up the buckle and cable together and gently pull the camera cable out of its channel securing it to the frame.
      • Free the cable so it's not wrapped around the corner of the laptop frame.
      Ask FixBot
    5. MacBook Neo Screen Removal, Free the display cable: step 5, image 1 of 2 MacBook Neo Screen Removal, Free the display cable: step 5, image 2 of 2
      • Hold the display cable's buckle and cable together and free it from the laptop frame.
      Ask FixBot
    6. MacBook Neo Screen Removal, Loosen the hinge screws: step 6, image 1 of 2 MacBook Neo Screen Removal, Loosen the hinge screws: step 6, image 2 of 2
      • Use a Torx Plus 8IP driver to loosen (not remove) all four hinge screws.
      Ask FixBot
    7. MacBook Neo Screen Removal, Reassembly information: step 7, image 1 of 3 MacBook Neo Screen Removal, Reassembly information: step 7, image 2 of 3 MacBook Neo Screen Removal, Reassembly information: step 7, image 3 of 3
      • During reassembly:
      • Loosen the hinge screws at least one full turn.
      • Adjust the screen until it's correctly centered and aligned on each side. The screen should sit flush with the rest of the laptop.
      • You can stand the laptop up on one side to help align the screen. Support it with one hand while tightening the screws with the other.
      • Fully tighten the four hinge screws.
      • If the screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
      • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
      Ask FixBot
    8. MacBook Neo Screen Removal, Open the laptop: step 8, image 1 of 2 MacBook Neo Screen Removal, Open the laptop: step 8, image 2 of 2
      • Open the laptop all the way and gently place it keyboard side down on a table, so the screen hangs over the edge.
      • You can place a soft cloth under the keyboard to protect it.
      Ask FixBot
    9. MacBook Neo Screen Removal, Remove the hinge screws: step 9, image 1 of 3 MacBook Neo Screen Removal, Remove the hinge screws: step 9, image 2 of 3 MacBook Neo Screen Removal, Remove the hinge screws: step 9, image 3 of 3
      • Keep a firm grip on the laptop, as it can easily fall off the table.
      • Support the screen with one hand.
      • With your free hand, use a Torx Plus 8IP driver to remove the four 6.2 mm–long screws securing the hinges.
      Ask FixBot
    10. MacBook Neo Screen Removal, Remove the screen: step 10, image 1 of 3 MacBook Neo Screen Removal, Remove the screen: step 10, image 2 of 3 MacBook Neo Screen Removal, Remove the screen: step 10, image 3 of 3
      • Hold the screen with both hands and lift the hinges out of their recesses to remove it.
      • During reassembly, be careful not to scratch the new screen on the edge of the laptop frame. If the screen itself has any plastic liners, leave them in place until reassembly is complete.
      Ask FixBot
Finish Line
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 139
