Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Prerequisite only guide to remove the battery in a MacBook Neo.
Tools
Spudger4.9
Insert the point of a spudger beneath the headphone jack connector, located on the right side of the logic board directly above the battery, and pry it straight up to disconnect it.
Repeat to disconnect the left speaker connector, adjacent to the headphone jack connector.
Disconnect the right speaker connector, located on the opposite end of the logic board.
Gently lift the right speaker cable out of its channel around the battery.
Gently peel up the headphone jack cable and lift it out of its channel around the battery.
Use a Torx Plus 5IP driver to remove the eighteen 2.8 mm‑long screws securing the battery.
Don't remove the four tall screws marked in yellow.
Insert the flat end of a spudger beneath the battery's left edge and lift it until you can grab it with your fingers.
Tilt the battery upwards to a roughly 45‑degree angle and remove it.
