Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓Prerequisite only guide to connect the battery in a MacBook Neo.
Align the battery connector carefully over its socket and press down until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
Set the battery connector cover in place, aligned with its screw holes.
Use a Torx Plus 3IP driver to install the two 1.7 mm‑long screws securing the battery connector cover.
