MacBook Neo Antenna Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. MacBook Neo Antenna Removal, Remove the antenna connector cover: step 1, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the 1.7 mm‑long screw securing the antenna connector cover.
      Ask FixBot
    2. MacBook Neo Antenna Removal: step 2, image 1 of 2 MacBook Neo Antenna Removal: step 2, image 2 of 2
      • Use tweezers or your fingers to remove the antenna connector cover.
      Ask FixBot
    3. MacBook Neo Antenna Removal, Disconnect the antenna: step 3, image 1 of 3 MacBook Neo Antenna Removal, Disconnect the antenna: step 3, image 2 of 3 MacBook Neo Antenna Removal, Disconnect the antenna: step 3, image 3 of 3
      • Insert one arm of angled tweezers under the metal neck of one of the antenna coaxial connectors and lift straight up to disconnect it.
      • Repeat the process to disconnect the second antenna cable.
      • To reconnect, use tweezers to hold each connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
      Ask FixBot
    4. MacBook Neo Antenna Removal, Remove the antenna: step 4, image 1 of 1
      • Use a Torx Plus 5IP driver to remove the four 2.9 mm‑long screws securing the antenna.
      Ask FixBot
    5. MacBook Neo Antenna Removal: step 5, image 1 of 2 MacBook Neo Antenna Removal: step 5, image 2 of 2
      • Pick up the antenna by its edges and remove it.
      Ask FixBot
Finish Line
Nick Schultz
65,697 Reputation
343 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 81
