Installing MacBook Core Duo Left Speaker
  1. Installing MacBook Core Duo Left Speaker, Battery: step 1, image 1 of 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. Installing MacBook Core Duo Left Speaker: step 2, image 1 of 1
    • Lift the battery out of the computer.
  3. Installing MacBook Core Duo Left Speaker, Memory Cover: step 3, image 1 of 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the battery casing, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. Installing MacBook Core Duo Left Speaker: step 4, image 1 of 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. Installing MacBook Core Duo Left Speaker, Upper Case: step 5, image 1 of 1
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. Installing MacBook Core Duo Left Speaker: step 6, image 1 of 1
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. Installing MacBook Core Duo Left Speaker: step 7, image 1 of 1
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. Installing MacBook Core Duo Left Speaker: step 8, image 1 of 1
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. Installing MacBook Core Duo Left Speaker: step 9, image 1 of 1
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. Installing MacBook Core Duo Left Speaker: step 10, image 1 of 1
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. Installing MacBook Core Duo Left Speaker: step 11, image 1 of 1
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. Installing MacBook Core Duo Left Speaker: step 12, image 1 of 1
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. Installing MacBook Core Duo Left Speaker, Left Speaker: step 13, image 1 of 1
    • Disconnect the left speaker from the logic board.
  14. Installing MacBook Core Duo Left Speaker: step 14, image 1 of 1
    • Remove the following 2 screws:
    • One 6 mm Phillips securing the left speaker to the lower case.
    • One 8.5 mm Phillips in the upper right corner of the Airport card.
  15. Installing MacBook Core Duo Left Speaker: step 15, image 1 of 1
    • Deroute the left speaker cable from beneath the Airport antenna cables.
  16. Installing MacBook Core Duo Left Speaker: step 16, image 1 of 1
    • Deroute the left speaker cable from beneath the MagSafe cable.
    • Lift the left speaker up and out of the computer.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 14,265
