Installing MacBook Core 2 Duo Hard Drive Connector
  1. Installing MacBook Core 2 Duo Hard Drive Connector, Battery: step 1, image 1 of 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. Installing MacBook Core 2 Duo Hard Drive Connector: step 2, image 1 of 1
    • Lift the battery out of the computer.
  3. Installing MacBook Core 2 Duo Hard Drive Connector, Memory Cover: step 3, image 1 of 1
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
  4. Installing MacBook Core 2 Duo Hard Drive Connector: step 4, image 1 of 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
  5. Installing MacBook Core 2 Duo Hard Drive Connector, Upper Case: step 5, image 1 of 1
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle of the lower case.
  6. Installing MacBook Core 2 Duo Hard Drive Connector: step 6, image 1 of 1
    • Take extra caution with these screws as they can strip easily!
    • You could use a flexible extension to minimize stripping.
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  7. Installing MacBook Core 2 Duo Hard Drive Connector: step 7, image 1 of 1
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
  8. Installing MacBook Core 2 Duo Hard Drive Connector: step 8, image 1 of 1
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
  9. Installing MacBook Core 2 Duo Hard Drive Connector: step 9, image 1 of 1
    • Remove the following 4 screws from the back of the computer:
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
  10. Installing MacBook Core 2 Duo Hard Drive Connector: step 10, image 1 of 1
    • Remove the two Phillips screws from the optical drive (right) side of the computer:
    • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the ports (left) side of the computer.
  11. Installing MacBook Core 2 Duo Hard Drive Connector: step 11, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
    • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
    • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
    • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
  12. Installing MacBook Core 2 Duo Hard Drive Connector: step 12, image 1 of 3 Installing MacBook Core 2 Duo Hard Drive Connector: step 12, image 2 of 3 Installing MacBook Core 2 Duo Hard Drive Connector: step 12, image 3 of 3
    • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
    • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
  13. Installing MacBook Core 2 Duo Hard Drive Connector, Hard Drive Connector: step 13, image 1 of 1
    • Use the white plastic pull-tab to slide the hard drive to the left and out of the computer.
  14. Installing MacBook Core 2 Duo Hard Drive Connector: step 14, image 1 of 1
    • Disconnect the orange optical drive ribbon cable from the logic board.
  15. Installing MacBook Core 2 Duo Hard Drive Connector: step 15, image 1 of 1
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
  16. Installing MacBook Core 2 Duo Hard Drive Connector: step 16, image 1 of 1
    • Disconnect the (once again) newly-revealed hard drive cable.
  17. Installing MacBook Core 2 Duo Hard Drive Connector: step 17, image 1 of 1
    • Deroute the hard drive connector cable from the four tabs along the edge of the optical drive.
  18. Installing MacBook Core 2 Duo Hard Drive Connector: step 18, image 1 of 1
    • Remove the two Phillips screws securing the hard drive connector to the lower case.
  19. Installing MacBook Core 2 Duo Hard Drive Connector: step 19, image 1 of 1
    • Carefully lift the hard drive connector out of the case slightly, and turn it over to reveal the IR sensor connector beneath. Use a spudger to flip up the tiny bar holding the cable in place.
    • Slide the orange IR sensor cable out of its connector, and lift the hard drive connector out of the computer.
iRobot
1 Reputation
636 Guides authored
Past 24 Hours: 11
Past 7 Days: 30
Past 30 Days: 49
All Time: 54,886
