Installing MacBook Air Logic Board Bracket
  1. Installing MacBook Air Logic Board Bracket, Lower Case: step 1, image 1 of 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. Installing MacBook Air Logic Board Bracket: step 2, image 1 of 2 Installing MacBook Air Logic Board Bracket: step 2, image 2 of 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. Installing MacBook Air Logic Board Bracket, Battery: step 3, image 1 of 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. Installing MacBook Air Logic Board Bracket: step 4, image 1 of 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. Installing MacBook Air Logic Board Bracket: step 5, image 1 of 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. Installing MacBook Air Logic Board Bracket, Logic Board Bracket: step 6, image 1 of 1
    • Remove the two small Phillips screws securing the logic board bracket to the upper case.
  7. Installing MacBook Air Logic Board Bracket: step 7, image 1 of 1
    • Lift the logic board bracket out of the upper case.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 10,256
