MacBook Air Models A1237 and A1304 Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Air Models A1237 and A1304 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 MacBook Air Models A1237 and A1304 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 MacBook Air Models A1237 and A1304 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
    • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
  2. MacBook Air Models A1237 and A1304 Hard Drive Replacement: step 2, image 1 of 1
    • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
  3. MacBook Air Models A1237 and A1304 Hard Drive Replacement: step 3, image 1 of 1
    • Use a spudger to pry the hard drive cable connector up off the logic board.
  4. MacBook Air Models A1237 and A1304 Hard Drive Replacement: step 4, image 1 of 2 MacBook Air Models A1237 and A1304 Hard Drive Replacement: step 4, image 2 of 2
    • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
    • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
  5. MacBook Air Models A1237 and A1304 Hard Drive Replacement: step 5, image 1 of 1
    • Remove the four Phillips screws securing the hard drive assembly to the upper case:
    • Two 4.7 mm screws.
    • Two 3.9 mm screws.
  6. MacBook Air Models A1237 and A1304 Hard Drive Replacement: step 6, image 1 of 1
    • Lift the hard drive assembly out of the upper case.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 9,685
