MacBook Air 13" Retina Display 2019 Lower Case Replacement
  1. MacBook Air 13" Retina Display 2019 Lower Case Replacement, Remove the screws securing the lower case: step 1, image 1 of 1
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13" Retina Display 2019 Lower Case Replacement, Remove the lower case: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
Adam O'Camb
196,299 Reputation
416 Guides authored
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 98
All Time: 3,633
