MacBook Air 13" Mid 2011 Fan Replacement
  1. MacBook Air 13" Mid 2011 Fan Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2011 Fan Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2011 Fan Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 13" Mid 2011 Fan Replacement, Battery Connector: step 3, image 2 of 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. MacBook Air 13" Mid 2011 Fan Replacement, I/O Board Cable: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 13" Mid 2011 Fan Replacement: step 5, image 1 of 1
    • Carefully peel the I/O board cable from the top of the fan.
  6. MacBook Air 13" Mid 2011 Fan Replacement: step 6, image 1 of 2 MacBook Air 13" Mid 2011 Fan Replacement: step 6, image 2 of 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  7. MacBook Air 13" Mid 2011 Fan Replacement, Fan: step 7, image 1 of 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  8. MacBook Air 13" Mid 2011 Fan Replacement: step 8, image 1 of 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  9. MacBook Air 13" Mid 2011 Fan Replacement: step 9, image 1 of 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  10. MacBook Air 13" Mid 2011 Fan Replacement: step 10, image 1 of 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Finish Line
46 other people completed this guide.
6 Comments
i accidentaly ripped of the socket of the fan cabel,
can i just glue it back ate the contacts where it was ?
dani96an - Reply
I did the same thing I broke the retaining flap. I posted for assistance at this site a while back but I have had no answer. Is the retaining flap a replaceable item? I ordered a new fan thinking with would come included but nada
asini1 - Reply
I also broke the retaining flap. For now, I just reinserted the ribbon. Is the function of the retaining flap just to hold the ribbon in place? Since then my computer has been entering sleep mode/shutting down during use, but I also did a battery replacement recently.
bee.chelsie - Reply
Good stuff! Thanks.
VFRDon
Don Swanner - Reply
Got it flawlessly! Thanks!
Juan Cuevas - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 51
All Time: 35,259
