Installing MacBook Air 13" Mid 2012 I/O Board Cable
  1. Installing MacBook Air 13" Mid 2012 I/O Board Cable, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. Installing MacBook Air 13" Mid 2012 I/O Board Cable: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. Installing MacBook Air 13" Mid 2012 I/O Board Cable, Battery Connector: step 3, image 1 of 2 Installing MacBook Air 13" Mid 2012 I/O Board Cable, Battery Connector: step 3, image 2 of 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. Installing MacBook Air 13" Mid 2012 I/O Board Cable, I/O Board Cable: step 4, image 1 of 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. Installing MacBook Air 13" Mid 2012 I/O Board Cable: step 5, image 1 of 1
    • Carefully peel the I/O board cable from the top of the fan.
  6. Installing MacBook Air 13" Mid 2012 I/O Board Cable: step 6, image 1 of 2 Installing MacBook Air 13" Mid 2012 I/O Board Cable: step 6, image 2 of 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
Andrew Optimus Goldheart
503,280 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,410 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 40
All Time: 6,166
