Installing MacBook Air 13" Mid 2011 Microphone
  1. Installing MacBook Air 13" Mid 2011 Microphone, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. Installing MacBook Air 13" Mid 2011 Microphone: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. Installing MacBook Air 13" Mid 2011 Microphone, Battery: step 3, image 1 of 2 Installing MacBook Air 13" Mid 2011 Microphone, Battery: step 3, image 2 of 2
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
    • When reinstalling a new battery, it may be helpful to temporarily reconnect the battery before placing it in the frame. Make sure that the connector lays flat to the board.
  4. Installing MacBook Air 13" Mid 2011 Microphone: step 4, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  5. Installing MacBook Air 13" Mid 2011 Microphone: step 5, image 1 of 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. Installing MacBook Air 13" Mid 2011 Microphone, Left Speaker: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  7. Installing MacBook Air 13" Mid 2011 Microphone: step 7, image 1 of 1
    • De-route the left speaker cable from its retaining clip on the I/O board.
  8. Installing MacBook Air 13" Mid 2011 Microphone: step 8, image 1 of 3 Installing MacBook Air 13" Mid 2011 Microphone: step 8, image 2 of 3 Installing MacBook Air 13" Mid 2011 Microphone: step 8, image 3 of 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
  9. Installing MacBook Air 13" Mid 2011 Microphone, Microphone: step 9, image 1 of 1
    • Use the edge of a spudger to pry the microphone connector up and out of its socket on the I/O board.
  10. Installing MacBook Air 13" Mid 2011 Microphone: step 10, image 1 of 2 Installing MacBook Air 13" Mid 2011 Microphone: step 10, image 2 of 2
    • Use the tip of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
    • Remove the microphone from the upper case.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 11,043
