MacBook Air 13" Mid 2011 Battery Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Air 13" Mid 2011 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  2. MacBook Air 13" Mid 2011 Battery Replacement: step 2, image 1 of 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 638
