Installing MacBook Air 13" Late 2010 Lower Case
  1. Installing MacBook Air 13" Late 2010 Lower Case, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. Installing MacBook Air 13" Late 2010 Lower Case: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 10,358
