MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement
Video Overview
  1. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, Battery: step 3, image 1 of 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: step 4, image 1 of 2 MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: step 4, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 5, image 1 of 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 6, image 1 of 2 MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement: step 6, image 2 of 2
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • Remove the AirPort/Bluetooth board from the Air.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 29,430
