Porter-Cable 382 Sander Pad Replacement
    1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: step 1, image 1 of 1
      • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
      • Once the sander is upside down begin by removing your old sandpaper.
      • Once the sandpaper is removed locate the three screws on your sander pad.
      Ask FixBot
    2. Porter-Cable 382 Sander Pad Replacement: step 2, image 1 of 1
      • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
      • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
      Ask FixBot
2 other people completed this guide.
Nick O'Sadcia
448 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 101
All Time: 2,332
