ASUS MeMo Pad FHD10 Battery Replacement
    1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: step 1, image 1 of 2 ASUS MeMo Pad FHD10 Battery Replacement, Battery: step 1, image 2 of 2
      • Make sure that the device is turned off as a precaution.
      • Unplug the charger and remove any memory card you may have in the device.
      • Wedge the plastic opening tool between the front and back cover on every side.
      • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
      • Once disconnected, remove the back cover from the device screen.
      Ask FixBot
    2. ASUS MeMo Pad FHD10 Battery Replacement: step 2, image 1 of 2 ASUS MeMo Pad FHD10 Battery Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the protective copper sticker and all tape fixed on the device.
      • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
      • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
      Ask FixBot
    3. ASUS MeMo Pad FHD10 Battery Replacement: step 3, image 1 of 2 ASUS MeMo Pad FHD10 Battery Replacement: step 3, image 2 of 2
      • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
      Ask FixBot
    4. ASUS MeMo Pad FHD10 Battery Replacement: step 4, image 1 of 3 ASUS MeMo Pad FHD10 Battery Replacement: step 4, image 2 of 3 ASUS MeMo Pad FHD10 Battery Replacement: step 4, image 3 of 3
      • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
      • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
      • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
      Ask FixBot
5 other people completed this guide.
Dmitry
391 Reputation
3 Guides authored
USF Tampa, Team 9-5, Blackwell Winter 2015 Member of USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Members
60 Guides authored
1 Guide Comment
Where i can get new battery for this tablet?
Night Knight - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 87
All Time: 10,906
