Replacing MacBook Air 11" Mid 2013 I/O Board
  1. Replacing MacBook Air 11" Mid 2013 I/O Board, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. Replacing MacBook Air 11" Mid 2013 I/O Board: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. Replacing MacBook Air 11" Mid 2013 I/O Board, Battery Connector: step 3, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board, Battery Connector: step 3, image 2 of 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board Cable: step 4, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board Cable: step 4, image 2 of 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. Replacing MacBook Air 11" Mid 2013 I/O Board: step 5, image 1 of 1
    • Lift and remove the I/O board cable.
  6. Replacing MacBook Air 11" Mid 2013 I/O Board, Fan: step 6, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board, Fan: step 6, image 2 of 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. Replacing MacBook Air 11" Mid 2013 I/O Board: step 7, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 7, image 2 of 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. Replacing MacBook Air 11" Mid 2013 I/O Board: step 8, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 8, image 2 of 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. Replacing MacBook Air 11" Mid 2013 I/O Board: step 9, image 1 of 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. Replacing MacBook Air 11" Mid 2013 I/O Board: step 10, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 10, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 10, image 3 of 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. Replacing MacBook Air 11" Mid 2013 I/O Board, Battery: step 11, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. Replacing MacBook Air 11" Mid 2013 I/O Board: step 12, image 1 of 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board: step 13, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board, I/O Board: step 13, image 2 of 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. Replacing MacBook Air 11" Mid 2013 I/O Board: step 14, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 14, image 2 of 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  15. Replacing MacBook Air 11" Mid 2013 I/O Board: step 15, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 15, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 15, image 3 of 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  16. Replacing MacBook Air 11" Mid 2013 I/O Board: step 16, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 16, image 2 of 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  17. Replacing MacBook Air 11" Mid 2013 I/O Board: step 17, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 17, image 2 of 2
    • De-route the cable from its notch in the I/O board.
  18. Replacing MacBook Air 11" Mid 2013 I/O Board: step 18, image 1 of 2 Replacing MacBook Air 11" Mid 2013 I/O Board: step 18, image 2 of 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  19. Replacing MacBook Air 11" Mid 2013 I/O Board: step 19, image 1 of 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  20. Replacing MacBook Air 11" Mid 2013 I/O Board: step 20, image 1 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 20, image 2 of 3 Replacing MacBook Air 11" Mid 2013 I/O Board: step 20, image 3 of 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Sam Goldheart
466,202 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 43
All Time: 8,506
