Installing MacBook Air 11" Mid 2011 Microphone
  1. Installing MacBook Air 11" Mid 2011 Microphone, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. Installing MacBook Air 11" Mid 2011 Microphone: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. Installing MacBook Air 11" Mid 2011 Microphone, Battery: step 3, image 1 of 2 Installing MacBook Air 11" Mid 2011 Microphone, Battery: step 3, image 2 of 2
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. Installing MacBook Air 11" Mid 2011 Microphone: step 4, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  5. Installing MacBook Air 11" Mid 2011 Microphone: step 5, image 1 of 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. Installing MacBook Air 11" Mid 2011 Microphone, Left Speaker: step 6, image 1 of 1
    • Use the flat end of a spudger to pry the I/O board cable connector up off its socket on the I/O board.
    • Bend the cable away from the I/O board.
  7. Installing MacBook Air 11" Mid 2011 Microphone: step 7, image 1 of 1
    • Use the tip of a spudger to de-route the left speaker cable from the notch cut into the edge of the I/O board.
  8. Installing MacBook Air 11" Mid 2011 Microphone: step 8, image 1 of 1
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the I/O board.
    • Make sure to pry upward from beneath the wires.
  9. Installing MacBook Air 11" Mid 2011 Microphone: step 9, image 1 of 2 Installing MacBook Air 11" Mid 2011 Microphone: step 9, image 2 of 2
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
  10. Installing MacBook Air 11" Mid 2011 Microphone: step 10, image 1 of 1
    • Remove the left speaker from the upper case.
  11. Installing MacBook Air 11" Mid 2011 Microphone, Microphone: step 11, image 1 of 2 Installing MacBook Air 11" Mid 2011 Microphone, Microphone: step 11, image 2 of 2
    • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the microphone ribbon cable out of its socket.
  12. Installing MacBook Air 11" Mid 2011 Microphone: step 12, image 1 of 2 Installing MacBook Air 11" Mid 2011 Microphone: step 12, image 2 of 2
    • Use the tip of a spudger to pry the microphone away from the side of the upper case.
    • Remove the microphone from the upper case.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 6,509
