Installing MacBook Air 11" Mid 2011 Battery
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Air 11" Mid 2011 Battery, Battery: step 1, image 1 of 2 Installing MacBook Air 11" Mid 2011 Battery, Battery: step 1, image 2 of 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 925
