Installing MacBook Air 11" Late 2010 Battery
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing MacBook Air 11" Late 2010 Battery, Battery: step 1, image 1 of 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  2. Installing MacBook Air 11" Late 2010 Battery: step 2, image 1 of 1
    • Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 344
