MacBook Air 11" Early 2014 Lower Case Replacement
  1. MacBook Air 11" Early 2014 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2014 Lower Case Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Sam Goldheart
465,860 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,199 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 25
All Time: 3,279
