Installing Mac mini Model A1283 Speaker
  1. Installing Mac mini Model A1283 Speaker, Internal Frame: step 1, image 1 of 1
    • In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
    • We will first remove the AirPort antenna, located in the lower left corner of this picture.
  2. Installing Mac mini Model A1283 Speaker: step 2, image 1 of 2 Installing Mac mini Model A1283 Speaker: step 2, image 2 of 2
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
  3. Installing Mac mini Model A1283 Speaker: step 3, image 1 of 2 Installing Mac mini Model A1283 Speaker: step 3, image 2 of 2
    • The two Bluetooth antenna boards simply lift off the internal frame.
    • Grab the Bluetooth antenna nearest the port side of the computer by the edges of the board and pull it straight up off the internal frame.
    • Pull carefully, as it may offer significant resistance and release suddenly.
  4. Installing Mac mini Model A1283 Speaker: step 4, image 1 of 1
    • Remove the antenna board near the front of the mini by pulling it straight up off the internal frame.
    • If necessary, remove the piece of tape securing the antenna leads to the internal frame.
    • Be sure to keep track of the springs under each of the three antenna boards.
  5. Installing Mac mini Model A1283 Speaker: step 5, image 1 of 1
    • Use the flat end of a spudger to pry the audio ribbon cable connector up off the audio board.
  6. Installing Mac mini Model A1283 Speaker: step 6, image 1 of 1
    • Remove the following four screws securing the internal frame to the bottom housing:
    • Three 6.7 mm Phillips #00 screws
    • One 9.5 mm Phillips #00 screw
    • The screw in the lower right corner of this image is recessed deep in the internal frame and longer than the other three screws. A flashlight and a thin screwdriver aid in removal.
  7. Installing Mac mini Model A1283 Speaker: step 7, image 1 of 1
    • Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
    • When reassembling, the wifi antenna wire routes to the inside of the vent and then over the top of the vent.
  8. Installing Mac mini Model A1283 Speaker, Hard Drive: step 8, image 1 of 1
    • Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
  9. Installing Mac mini Model A1283 Speaker: step 9, image 1 of 1
    • Remove the two Phillips screws securing the side of the hard drive to the internal frame.
  10. Installing Mac mini Model A1283 Speaker: step 10, image 1 of 1
    • Use the flat end of a spudger to pry the hard drive thermal sensor board off the adhesive securing it to the side of the hard drive.
  11. Installing Mac mini Model A1283 Speaker: step 11, image 1 of 1
    • Remove the strip of tape holding the thermal sensor cable to the hard drive and remove the thermal sensor from the hard drive.
    • You'll want to transfer this thermal sensor to the same position on your new hard drive.
  12. Installing Mac mini Model A1283 Speaker: step 12, image 1 of 2 Installing Mac mini Model A1283 Speaker: step 12, image 2 of 2
    • Slide the hard drive toward the speaker to disconnect it from the interconnect board.
    • Lift the hard drive from the edge opposite the fan and remove it from the internal frame.
  13. Installing Mac mini Model A1283 Speaker, Speaker: step 13, image 1 of 1
    • Disconnect the speaker cable connector from the interconnect board by lifting its connector up off the socket on the board.
  14. Installing Mac mini Model A1283 Speaker: step 14, image 1 of 1
    • Use the tip of a spudger to de-route the speaker cable from the clip on the internal frame.
  15. Installing Mac mini Model A1283 Speaker: step 15, image 1 of 1
    • De-route the speaker cable from within the channel in the internal frame.
  16. Installing Mac mini Model A1283 Speaker: step 16, image 1 of 1
    • Remove the four shouldered Phillips screws securing the speaker assembly to the internal frame.
  17. Installing Mac mini Model A1283 Speaker: step 17, image 1 of 1
    • Lift the speaker out of the internal frame.
    • During reassembly, be sure to thread the speaker cable through the opening in the internal frame before fastening the screws down.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 24
All Time: 9,040
